I am trying to create separate groups on each primitive after they have been created. Similar to how the Output Group Prefix works in the Copy and Transform node, by creating individual groups for each primitive copied. The primitives here are not copied, they are procedural.
I have tried setting up a For Each Loop with a group expression, that only grouped them together. I'm a bit stuck at the moment, thanks.
Glen
Create individual groups based on Primitive Number
2454 3 1- GlenD
- 118 posts
- protozoan
- 1668 posts
Not sure if I'm missing something obvious, but the partitionSOP should do exactly what you need.
Try it out: put it down, make sure the “Entity” parameter is set to Primitive, and enter something as the rule like
This should give you, in your example, 5 groups named group_0 to group_4.
group_`@primnum`
Martin Winkler
money man at Alarmstart Germany
- GlenD
- 118 posts
protozoan
Try it out: put it down, make sure the “Entity” parameter is set to Primitive, and enter something as the rule likegroup_`@primnum`
Thanks Protozoan,
That's exactly what I was trying to accomplish! I was over thinking this way too much and I appreciate the assistance.
Glen
- sekow
- 238 posts
