Setting @P.y Flatten PolyFill
1538
8
0
RyuKu
Jan. 13, 2020 3:09 p.m.
Hello
after polyfill (gives round shape bottom) wanted to flatten points them being on one line
if i know numbers of them i think is it correctly or is there a better way if about Wrangle?
if (@ptnum >= 840 )
if (@ptnum <= 1035 )
@P .y = -2.08414 ;
else if doing it with VOPs how to connect group to @P.y if setattrib doesn't even have right outputs and them to global output?
Edited by RyuKu - Jan. 13, 2020 18:02:41
jsmack
Jan. 13, 2020 3:13 p.m.
Put the point selection in the group field of the attribute wrangle. But wouldn't it be easier to change the settings on the polyfill to output a flat bottom to begin with?
goldfarb
Jan. 13, 2020 3:48 p.m.
turn OFF Deform Patch on the PolyFill - that should make a flat surface.
Michael Goldfarb |
www.odforce.net Training Lead
www.sidefx.com
jsmack
Jan. 13, 2020 4:46 p.m.
goldfarb turn OFF Deform Patch on the PolyFill - that should make a flat surface.Thanks, I didn't remember what the setting was called. I just knew there was one.
vusta
Jan. 13, 2020 7:14 p.m.
I think the deform should by default be off , it's very annoying and rarely used…just me.
jsmack
Jan. 13, 2020 7:27 p.m.
But muh C3 continunity
