Redshift Crowd Workflow
   5384   5   0
Hey guys just wondering if there is a workflow for using Redshift with crowds in Houdini. I tried style sheets but it doesn't seem to be compatible. I saw online about a shader switch method but not sure how that would work with Houdini agents. Any ideas?
**UPDATE**
So Saul Espinosa helped me on the redshift facebook group, he said “To support the materials override in the agents from the “agentshapename” attribute, the plugin promote this attribute as “name” to all the final primitives once the agent is expanded at the extraction time, so in your case you only need to set as “Primitive name or path Attribute” condition the agent shape name.”
So basically just need to have target primitive, and change the condition to primitive name or path attribute since that's how redshift looks for the agents at render time.
Edited by mannyw - Jan. 22, 2020 15:12:39
mwillustrations
**UPDATE**
Saved my life, thanks.
Thanks!!!!!
Nice!! Do you know how to setup with randomize texture? I create an attribute randomize "texture"
what I'm missing here
I am not sure I understand it right about renaming the name to condition agent shape name?
Skærmbillede 2023-12-09 152639.png (1.3 MB)
Is this right?
Skærmbillede 2023-12-09 153625.png (258.5 KB)
