Our pipeline's file system uses Samba file sharing, and it seems to work for everything but Houdini's USD Rop.
While I am able to write out any other file type from Houdini to a network drive with no issues, Attempting to write out a USD file from the USD Rop results in a permissions error. However if I write the same USD to my local drive or via and admin share it works fine.
Any ideas what is going wrong? This is a major issue for our studio's adoption of Solaris.
Issues with Writing USD Files over Samba
2804 5 1- Ashen
- 78 posts
- mtucker
- 4511 posts
- Ashen
- 78 posts
Okay, tested it in a python script LOP and I still get the same error. Here is the code:
If I try to create a new stage in the Houdini python shell like so, I get the same error as soon as I create the stage.
Is it possible that the process creating the files isn't inheriting my user privileges?
I don't have USD installed at the system level, but I imagine if I were to try it from there I would have the same issue.
This is starting to feel like a USD specific question. Is there a good forum to ask this in?
node = hou.pwd() stage = node.editableStage() root_node = hou.node('../Barrel_Root') root_path = root_node.parm('root_path').evalAsString() # Returns a directory on the Samba share root_path += 'geo/PythonBarrel.usd' stage.Export(root_path)
from pxr import Usd stage = Usd.Stage.CreateNew(r'<Network path>\test\test.usd')
Edited by Ashen - Jan. 28, 2020 15:10:24
- mtucker
- 4511 posts
Yes, this does sound like it's something inside of USD causing this issue. There is the usd-interest Google Group (https://groups.google.com/forum/?utm_source=digest&utm_medium=email# [groups.google.com]!forum/usd-interest/topics) which is frequented by Pixar developers and a wide cross section of users. In fact, I just did a search for “samba” in that group and there is a thread indicating someone else had the same issue as you, but they didn't post a resolution… https://groups.google.com/forum/?utm_source=digest&utm_medium=email# [groups.google.com]!searchin/usd-interest/samba%7Csort:date/usd-interest/Kf4nV2QdoLg/8nx15yCaBwAJ
- Ashen
- 78 posts
- nuclear_polygon
- 21 posts
