Hello, just to keep in mind I am a beginner with Houdini.
I recently saved and HDA but whenever I click on it from the list of operators (it shows up fine) it does not actually add it to my network.
I think this topic here encountered the same issue: https://forums.odforce.net/topic/18780-cant-use-digital-asset/ [forums.odforce.net]
however I do not understand the solution.
This is the third time I've redone this HDA so I prefer not remaking an entirely new one..
My HDA cannot be selected form the list
1704 3 0- is
- 4 posts
- bobc4d
- 327 posts
- is
- 4 posts
it is version 18.0.287 FX
I created it then started editing parameters before noticing the issue. Its not too big of a deal to redo all of the parameters I have set but I'd rather not waste a couple hours if there is a solution out there.
I didn't actually check if I could put it down when I first created it so it may have been an issue from the moment of its creation to the time I had last saved it and tried placing it.
If I copy paste the node in the same graph it pastes fine. its just trying to bring it in via the tab operator finder that it does not.
Edited by is - Jan. 29, 2020 01:49:48
- bobc4d
- 327 posts
