What nodes can I use instead of "poin-old" node?
   2917   3   1
My purpose is to raise the height of the group on the y-axis only.
However, when I use a H18, I don't have that node, and I get an error when I apply the wrangle node.
Which node should I use to make it look like the attached image?
in new Point SOP, VEXpression: (put ‘yourgroupname’ in Group to affect only your subset of points)
set(@P.x, @P.y + 0.5, @P.z)
so x,z are unchanged, while Y has 0.5 added to it
(while you're in the new point SOP, just click on the dropdown arrow to look at presets and learn from them)
Edited by vusta - Feb. 10, 2020 21:43:26
Thank you
vusta
in new Point SOP, VEXpression: (put 'yourgroupname' in Group to affect only your subset of points)
that's a great tip about the dropdown arrow, thank-u : )
