Custom Variadic Vex Functions
2307
5
1
- traden1976
- 22 posts
I'm looking at a way of creating a custom function in Vex any number of trailing params.
The closest reference I could find is here:
https://www.sidefx.com/docs/hdk/_h_d_k__vex_op.html [
www.sidefx.com]
but I don't understand it.
eg.
void myFunc(int arr_i[]; string arr_s; string ...extra_params) {
s@debug = extra_params[0];
here's a go lang example:
Go Variadic [
gobyexample.com]
Is this possible? If so can someone give me a simple example?
Thanks in advance!
Edited by traden1976 - Feb. 13, 2020 07:50:59
- Ommlet
- 3 posts
Hi traden1976!
Could you please elaborate a little bit, what you try to implement?
- traden1976
- 22 posts
Hi Ommlet, I want to pass in an arbitrary amount of arrays to be populated. But it's more for the sake of curiosity VS being stuck on a problem.
Just wondering if it's actually possible.
thanks!
- kahuna031
- 897 posts
This way of declaring functions isn't supported. You should give it a string array instead.
Edited by kahuna031 - Feb. 13, 2020 13:40:22
B.Henriksson, DICE
- traden1976
- 22 posts
Thanks for researching and replying guys! I'll look at different approaches.
