Hi there,
Two things im trying wrap my head around in hom/python.
On a node like a python sop, when you add an attribute manually, it gets added to the root folder?
I can see that entries/ attributes can be stored at root via:
node.parmTemplateGroup().entriesWithoutFolders()
All the code examples i can see, when i add a attribute via python it has to be via a folder.
Is there something im missing?
Secondly, on a switch node, how can i query/ update/ reorder things plugged in via python?
Cheers
Kym
Python: add attr to root template folder and switch order
932 2 1-
- Kym Watts
- 36 posts
- Kym Watts
- 36 posts
so i figured out the switch problem, it looks like its just easier to rebuild the input list from scratch if i want to reorder things.
Still interested in knowing how to add to the root folder for parms on an node.
You can do this by hand in the Parameter interface, but i cant seem to figure this out in python.
Any thoughts?
Cheers
Kym
n.setInput(<input number>, <childnode>)
Any thoughts?
Cheers
Kym
- krueger
- 191 posts
