Hi
I have import a simple model , the model has value in x & y coordinate but the pivot is in origin. I did “move pivot to center” in modify shelf and done. I have a camera which I want to look at the model (constraint) .
active the look at in shelf select camera , enter , select the model , enter and then again enter, the problem is here.
instead the camera look at the model , look at the origin?? 0,0,0
I test with simple cube and cylinder and everything is okay
I think when I move pivot to center, the constrain do not look the new placement of pivot, ??? how can I freez (clean) the pivot translate? or the is there other solution?
Thank youu
Look At Problem with pivot
1208 1 1- FarrokhSarram
- 40 posts
- anon_user_89151269
- 1755 posts
