sidefx Labs Path Deform issue...
   1574   3   0
Hi;
I tried to use "SideFX Labs Path Deform", but the geometry follows only rough version of my curve, and it is not exactly placed on the path.
How can I fix this?
Thanks for helping.
Test_A_01.hip (387.8 KB)
Masoud Saadatmand (MSDVFX)
Try increasing the Curve Resolution on the Path Deform node.
we've been thru this (Feb), i even recall the shape of the curve…
https://forums.odforce.net/topic/45052-sidefx-labs-path-deform-issue/?tab=comments#comment-211485 [forums.odforce.net]
Edited by vusta - April 23, 2020 06:01:10
I've found, similar to Convex Decomposition, that you can get better quality results by scaling up the input curves/geo.
In my case, it was wrapping a bandage around a rodent's limbs and, without scaling 100x, the output geo was empty.
Edited by dandeentremont - Jan. 1, 2025 13:03:33
