Volume Rendering Issue
   Views 1465   Replies 2   Subscribers 0
Hi,guys.
I have bumped into a rasterized volume rendering issue.
I scattered some points on a polygon sphere's surface , then used a “volume rasterize attributes” node to convert points to volume and simply assigned a Cloud material to it.
It seems work fine in viewport , but in rendering it didn't work and couldn't get any results at all.
Did I miss something during the progress?
2020-03-05 113807.jpg (30.5 KB)
volumeCloudTest.hipnc (513.0 KB)
it's because your density attribute is a vector since you created it from Cd
just Bind Export density float attribute directly from your vop instead
tamte
Thank you for the help
