Failed to import duplicate module 'partitioners' which was p
   2699   1   0
Hi, I am having this message in my houdini console when i open houdini.
PDG Type Registry: Failed to import duplicate module ‘houdini’ which was previously imported from ‘C:/PROGRA~2/Steam/STEAMA~1/common/HOUDIN~1/houdini/pdg/types\houdini’
It was working fine, but now all the plugins doesnt work. Redshift,I cant update sidefx labs.
Please it would be great if i could get the assistance need.
I have the latest build for houdini 18 indie running through steam.
Thanks in advance
run Command Line Tools 18.0.391
>hconfig
check HOUDINI_PATH for duplicates, if there same path's twice or ;&;& in the end
then in houdini.env check #HOUDINI_PATH
something like this will generate “duplicate error” with SideFX Labs
HOUDINI_PATH=“${HOUDINI_PATH};&”
