maybe I am totally stupid but I am not able to install houdini.
I downloaded both linux versions and when I try to run the houdini_install script of one of them I get the following:
./houdini.install: 765: let: not found
In my directory I have three files:
houdini.install
houdini.tar.gz
sesinetd.install
I am totally confused :cry:
Need help installing houdini under ubuntu
7009 9 4- Brain
- 11 posts
- lisux
- 581 posts
BrainTry this:
houdini.install
houdini.tar.gz
sesinetd.install
sudo sh ./houdini.install
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- Brain
- 11 posts
- digitallysane
- 1192 posts
- Brain
- 11 posts
- digitallysane
- 1192 posts
- thomaskinga
- 65 posts
Hi..
Looks like a shell problem..
Simply put, a shell is the environment which allows you to enter commands at
the command prompt eg. dos, csh,ash,ksh, bash etc…
The “let” command can be found in most shells, except the C shell.
So it is best to run the install command in a shell which allows for the “let” command.
eg.. bash or ksh.
And do remember, to install houdini you really need to have root access or sudo setup.
The steps…
su (become root user, you need to know/remmember your root password)
cd /install-directory (goto the install script directory, ie houdini.install)
bash (change your shell to bash or ksh)
./houdini.install) (start the install script)
exit (exit the bash shell)
exit (exit the root session)
That really should do it..
DON'T forget to enter twice, or you will still be logged in as root, which
could spell disaster as you know.
Good luck.
Regards
Tom
eg.. bash or ksh.
The steps…
Good luck.
Regards
Tom
- Brain
- 11 posts
- graham
- 1921 posts
Take a look at this thread.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=30619&highlight=#30619 [sidefx.com]
- Brain
- 11 posts
Not it is working
But when I try to get an nc_license I get an error that my version 8.2 is not supported
When I go to http://license.sidefx.com/get_nc_license.php [license.sidefx.com] I can only get a license for version <=8.1.
Edit:
After getting the license for version 8.1 manually it is working now.
Thanks everybody.
Not it is working
Edit:
Thanks everybody.
