How can I transfer UV from polygon to volume?
   4075   4   3
Hi;
I would like to create a VDB from a polygon (that contains UV texture) and after some deformations (like anti-alias noise), I would like to convert it back to polygon.
I tried to transfer UV attribute from volume to deformed polygon by turning the “Transfer Surface Attribut” option ON, in “ConvertVDB SOP”, but it doesn't work in some parts of the final result.
Thanks for helping.
uv_Volume.hip (194.6 KB)
Masoud Saadatmand (MSDVFX)
Can you get the result you want by using attribute transfer?
Have you tried the Attribute from Volume SOP?
Sean Rowe
I tried “Attribute from Volume”, but I don't know why it doesn't works properly.
It's not possible. UV's are a topologically defined property. Converting to a volume throws out the topology, and converting back to polygons produces an unrelated topology. The best you can do is proximity transfer, but if the uv has seams, they will not be preserved correctly, and faces that straddle a seam will be rendered incorrectly.
Edited by jsmack - March 13, 2020 17:14:16
