Houdini render volume with depth
   5363   7   0
Hello,guys!just rendering volume with redshift ,and need depth(Zdepth)for compositing.I have searched documentation and solution on web,but no answer…
So..i just wonder everyone here when meets this kind of situation…how did you guys solve it ??Or maybe any other things like depth that redshift can provide for compositor?
Zdepth makes no sense for semi transparent renders.. you will need to render out a deep camera map pass.
https://www.sidefx.com/docs/houdini/render/dcm.html [www.sidefx.com]
Deep don't work with volumes yet in Redshift.
JordanWalsh
thank you,i checked this thread and found it is a mantra way..so Redshift cant provide this deep camera map pass?
Heileif
So I have to change to Mantra to get Deep, or is there a way for Redshift to get a fake Deep for volume?
Need to use Mantra.
Mantra renders volumes fast, as long you don't use indirect lights.
Heileif
Need to use Mantra.
Thanks,I will give it a try
Heileif
hahaha, good one
FX Supervisor
Method Studios, NY
