Loop to Blendshape?
   1414   0   0
Hi all,
I need to export a cloth simulation to FBX blendshapes. Manually feeding each frame into a blendshape node works well, but I want to have a more elegant setup. So I considered using a loop with a TimeShift node to output every other/n-th/whatever frame. Now how can I have the output objects of the loop fed into the blendshapes node?
