Entagma Coloured Smoke trouble
   1592   2   0
Hey, just following Entagmas coloured smoke tutorial and running into an issue at the end. Unable to see my smoke as coloured at all. Need to input “density” into the density field to even see my smoke but it stays white and not the colour I inputed in my attributefrom map. I can use any image and it doesn't work.
Any help appreciated.
ColouredSmoke_01.hip (3.9 MB)
You should address OUT_COLOUR not OUT_COLLIDER in SOP Path parameter of volumesource_colour node!
See the HIP file.
Edited by N-G - April 4, 2020 07:55:04
ColouredSmoke_01 FIXED.hip (3.9 MB)
That's perfect thank you, I also noticed my diffuse ramp was solid white for some reason compared to yours. Thank you that fixed it
