Custom attribute not available on building_generator node
   Views 1411   Replies 1   Subscribers 0
Hi friends,
I recently started my first project in Houdini, using building_generator node + open street map data.
I got stuck when I tried to use a custom created attribute in Facade Module Pattern
An attribute named “windowname” is created in an attribute wrangle node. I intend to use it in Facade Module Pattern in buliding_generator node. It should assign window01 module to a group of buildings, and window02 module to the rest.
I can still see the “windowname” attribute on attribwrangle2 node before it goes into building_generator node.
But, I can't see/use “windowname” attribute on building_generator. I've checked primitive/points/vertex/detail parameters… Not existing.
My 2 questions are
1) where is “windowname” attribute on building_generator? why disappearing?
2) what is the best way to assign “windowname” to Facade Module Pattern in buliding_generator?
Thank you!
Anyone can help me understand how to use a custom created attribute(@windowname) on building_generator node?
