Error writing geo (ROP Geometry Output)
   2854   2   0
Hi guys,
My first experience using TOPS has unfortunately not gone that well . Doing the first entagma tutorial about the subject, but my issue seems to be on the write node, I fear there could be something on my system not allowing this to run?
My ROP Geometry Output is giving me an error when try to write the geometry (all dots become red). No geometry is exported to the folder. I am using the localscheduler with it's default values (though I tried other options and nothing worked). Same with the OutputFile values, nothing crazy going on here.
Any ideas what could be causing this issue?
Thanks in advance!
Cris
Here is the LOG:
Hide log
[Redshift] Redshift for Houdini plugin version 3.0.17 (Mar 13 2020 15:34:01)
[Redshift] Plugin compile time HDK version: 18.0.348
[Redshift] Houdini host version: 18.0.348
[Redshift] Plugin dso/dll and config path: Z:/VAULT/SOFTWARE/3D/REDSHIFT/redshift_v3.0.17/Redshift/Plugins/Houdini/18.0.348/dso
[Redshift] Core data path: C:\ProgramData\Redshift
[Redshift] Local data path: C:\ProgramData\Redshift
[Redshift] Procedurals path: C:\ProgramData\Redshift\Procedurals
[Redshift] Preferences file path: C:\ProgramData\Redshift\preferences.xml
[Redshift] License path: C:\ProgramData\Redshift
[Redshift] RAISING EXCEPTION: Shader node creation failed for 'AddLinear'! Version too old for this plugin.
  File "<string>", line 8, in <module>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.348/houdini/python2.7libs\hou.py", line 77908, in <module>
    __createHoudiniInternals()
hou.OperationFailed: The attempted operation failed.
  File "C:/Users/ntropic/AppData/Local/Temp/houdini_temp/PDG_entagma_v001/pdgtemp/67236/scripts/rop.py", line 37, in <module>
    import hou
165740: Fatal error: Segmentation fault
-- TRACEBACK BEGIN --
Traceback from hython 18.0.348 (Compiled on windows-x86_64-cl19.16):
CURRENT THREAD 194172
+0x117f773f [UT_StackTrace::doTracebackIntoBuffer] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x117f745c [UT_StackTrace::doTraceback] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x114459db [UT_CrashHandler::setApplicationName] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x117789a4 [UT_Signal::processSignal] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x8bfdc043 [seh_filter_exe] C:\WINDOWS\System32\ucrtbase.dll
+0x4000613c C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\hython.exe
+0x7ec8c1c0 [_C_specific_handler] C:\WINDOWS\SYSTEM32\VCRUNTIME140.dll
+0x8f0811cf [_chkstk] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8f04a209 [RtlRaiseException] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8f07fe3e [KiUserExceptionDispatcher] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x5cca91a4 [PyInterpreterState_Delete] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\python27.dll
+0x5cca9cb1 [PyGILState_Ensure] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\python27.dll
+0x001a7703 [PY_InterpreterAutoLock::PY_InterpreterAutoLock] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libPY.dll
+0x24b8d894 [HOM] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libHOM.dll
+0x39c7fc33 [newSopOperator] Z:\VAULT\SOFTWARE\3D\REDSHIFT\redshift_v3.0.17\Redshift\Plugins\Houdini\18.0.348\dso\redshift4houdini.dll
+0x39c87e89 [HoudiniCompilerVersion] Z:\VAULT\SOFTWARE\3D\REDSHIFT\redshift_v3.0.17\Redshift\Plugins\Houdini\18.0.348\dso\redshift4houdini.dll
+0x11491d5a [UT_Exit::doExit] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x5ccb9d0d [Py_Finalize] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\python27.dll
+0x5cb7449c [Py_Main] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\python27.dll
+0x400040f7 C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\hython.exe
+0x400051d0 C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\hython.exe
+0x8d3d7bd4 [BaseThreadInitThunk] C:\WINDOWS\System32\KERNEL32.DLL
+0x8f04ce51 [RtlUserThreadStart] C:\WINDOWS\SYSTEM32\ntdll.dll
OTHER THREAD 263488
+0x8f07fa04 [NtWaitForWorkViaWorkerFactory] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8f013fe0 [RtlInitializeResource] C:\WINDOWS\SYSTEM32\ntdll.dll
OTHER THREAD 297148
OTHER THREAD 90592
OTHER THREAD 49512
+0x8f07c6f4 [NtDelayExecution] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8c256891 [SleepEx] C:\WINDOWS\System32\KERNELBASE.dll
+0x1182d4c8 [UT_ThreadSafeCache<UT_Lock>::unsafe_end] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x1182d43d [UT_ThreadSafeCache<UT_Lock>::unsafe_end] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x1182d3c9 [UT_ThreadSafeCache<UT_Lock>::unsafe_end] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\libUT.dll
+0x8bf90e72 [beginthreadex] C:\WINDOWS\System32\ucrtbase.dll
OTHER THREAD 254052
+0x8f07c0f4 [NtWaitForSingleObject] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8c248b03 [WaitForSingleObjectEx] C:\WINDOWS\System32\KERNELBASE.dll
+0x2635e222 [tbb::internal::thread_sleep_v3] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\tbb.dll
+0x2635e10b [tbb::internal::thread_sleep_v3] C:\PROGRA~1\SIDEEF~1\HOUDIN~1.348\bin\tbb.dll
OTHER THREAD 164684
OTHER THREAD 299556
OTHER THREAD 90608
OTHER THREAD 117144
OTHER THREAD 155364
OTHER THREAD 167676
OTHER THREAD 121208
OTHER THREAD 133488
OTHER THREAD 262192
OTHER THREAD 309724
OTHER THREAD 58424
OTHER THREAD 168864
OTHER THREAD 210052
OTHER THREAD 152476
OTHER THREAD 160580
OTHER THREAD 154268
OTHER THREAD 31120
OTHER THREAD 113284
OTHER THREAD 166512
OTHER THREAD 288924
OTHER THREAD 23460
OTHER THREAD 170120
OTHER THREAD 90904
+0x334d3e5a [RSBlockSink::Save] Z:\VAULT\SOFTWARE\3D\REDSHIFT\redshift_v3.0.17\Redshift\bin\redshift-core-vc100.dll
+0x334d57d0 [RSBlockSink::Save] Z:\VAULT\SOFTWARE\3D\REDSHIFT\redshift_v3.0.17\Redshift\bin\redshift-core-vc100.dll
+0x5e2d1d9f [endthreadex] C:\WINDOWS\SYSTEM32\MSVCR100.dll
+0x5e2d1e3b [endthreadex] C:\WINDOWS\SYSTEM32\MSVCR100.dll
OTHER THREAD 236120
OTHER THREAD 156724
OTHER THREAD 226564
OTHER THREAD 240592
OTHER THREAD 145268
OTHER THREAD 87344
OTHER THREAD 135516
OTHER THREAD 246516
OTHER THREAD 22612
OTHER THREAD 181332
OTHER THREAD 50800
OTHER THREAD 278168
OTHER THREAD 213044
OTHER THREAD 158368
OTHER THREAD 5944
OTHER THREAD 118476
OTHER THREAD 72948
OTHER THREAD 174692
OTHER THREAD 138376
OTHER THREAD 226348
OTHER THREAD 264956
OTHER THREAD 94864
OTHER THREAD 162352
OTHER THREAD 41960
+0x8f07cbc4 [NtWaitForMultipleObjects] C:\WINDOWS\SYSTEM32\ntdll.dll
+0x8c268037 [WaitForMultipleObjectsEx] C:\WINDOWS\System32\KERNELBASE.dll
+0x8db6b50b [CoIncrementMTAUsage] C:\WINDOWS\System32\combase.dll
+0x8db6b390 [CoIncrementMTAUsage] C:\WINDOWS\System32\combase.dll
+0x8db6b1bc [CoIncrementMTAUsage] C:\WINDOWS\System32\combase.dll
+0x8db6b13c [CoIncrementMTAUsage] C:\WINDOWS\System32\combase.dll
OTHER THREAD 72532
OTHER THREAD 219044
-- TRACEBACK END --
I think at least you need to try to test the same scene, but without the Redshift plugin loaded. Because exceptions cause exactly Redshift plugin.
alexwheezy
Thanks Alex,
You are totally right. Somehow Redshift was causing this not to work. Even though I saw the error, couldn't believe this was the issue!!!
Cheers again
