Alembic to be simulated in dops
   1225   1   0
Bonjour, hope you all doing great.
i can't get an alembic geo to be simulated in dops .. however if i made a simple animated geo with keyframe animation,i can switch from being active in dops and reading the animation but it doesn't work with alembic..
should i be baking the alembic to keyframes or how it works?
Thank you.
Are you unpacking the alembic first? An alembic comes in as file reference by default – it's not actually loaded by Houdini until you render it or unpack it.
