Edit editable node inside HDA from outside the HDA?
   3059   1   2
I was very curious if this is possible,
I have an HDA with an ‘editable node’ inside it, (which is an Edit SOP).
Now is it possible to edit this Edit SOP when I have the HDA selected and press Enter,
instead of having to dive into the network, select the Edit SOP and pressing Enter?
*edit: or rather, when I use the select tool with the HDA selected, instead of using the select tool when the Edit SOP is selected inside the HDA by the user after diving in.
Thanks,
Edited by OdFotan - May 19, 2020 15:03:11
I'm also searching how to do that.
I'm not sure but Node tab > Editable Nodes might work.
https://www.sidefx.com/forum/topic/53135/#post-238837 [www.sidefx.com]
