Hi there,
Somehow the depth of field is not working anymore in 18.0.416. I also tried the trusted “cut and paste” but this never worked.
Also I can not get the motion blur to work. Is there a doc to explain how to setup a scene with animation data in the usd context?
Thank you very much! Best Regards
Camera Depth of Field not working in 18.0.416 / Motion Blur
4712 5 1- Roman S
- 7 posts
- jsmack
- 8038 posts
- Roman S
- 7 posts
- jsmack
- 8038 posts
Roman S
Thank you very much for your help! I finally got both to work, but only through “offline” rendering via husk. In the viewport delegate rendering there are still not working. I suppose the version 18 is internally regarded as a legacy viewport . So the bugfixes are very sparse.
Weird, working fine here in 18.0.460. There's a bit of an update bug. I have to display a rendersettings node first and karma will render with dof in the ipr view.
- yanndrevon
- 6 posts
Hi friends,
I am trying to get motion blur from an animated camera, my objects are statics, only the camera is moving. I tried layering differents nodes in different way, but I didn't succeed.
I can't help but thinking that it is simple, do you know how I can achieve it ?
This is my layering inside LOPS:
Thanks a lot !
Cheers
Thanks a lot !
Cheers
Edited by yanndrevon - June 17, 2020 12:15:14
Yann
Yann
- jsmack
- 8038 posts
