Problem with the GameDev Motion Vectors
   2080   1   0
I saw the tutorial of Mike Lyndon from 2017 about how to export pyro from the GameDev Montion Vectors.
- I'm having a bit of a problem with my output picture.
I can't import it because it makes an error in UE4 telling me I can't import it or it crashes my UE4 project.
- How to get all the frames of the pyro simulation on the same map ?
At the moment, all the frames are separated and doesn't look like the Motion Vector Map.
- The colors of my beauty are weird.
It is full of colour instead of the original colour.
I tried to make a Map of my Output Picture with the Slate Editor software and I realized that the whole .exr sequence is not the same proportion. I link in the topic the sequence and the Motion vector map.
I use Houdini 17.5 for some reason and UE4 4.25.0.
Output_Picture_And_Motion_Vector_Map.zip (11.0 MB)
Quick Update :
I didn't find an answer for the buged node (for me).
So I created my own setup to make the Motion Vector and everything works. So I was able to fit all the smoke frames in the same map and they're not full of color. I think it was filled with color because there was information in every channel of the RGB. I couldn't find any documentation about it.
I am able to integrate my maps on UE4 without crashing now.
If the problem happens to several people, Mike Lyndon can update the Motion Vector node and make a new video or some documentation about that. That would be appreciated.
Edited by Gridz-sama - May 26, 2020 09:56:09
