How to copy point attribute to channel (box position)
   1919   2   2
I apologize in advance for my English. I have a flying points in one geo. I want to put the camera on one of them. I used “point”, but it doesn't work. I started with box. I used them separately. Combined in vex only to show.
There is a point, attributes too.
I used “opinputpath” to check the correctness of the path
Maybe I don’t notice something elementary?
attr P.PNG (43.7 KB)
You're confusing your HScript expression syntax with VEX.
At the Object level where Cameras live, you'll have to use HScript to fetch information from a single point. The syntax looks like this:
point("/path/to/SOP", 164, "P", 0)
where 164 is the point number you're fetching attributes from, and 0 is the index of the attribute you're trying to fetch (0 corresponds to the X-coordinate of a vector attribute). For Y and Z, your expression would look the same, except the last term would be 1 and 2, respectively.
Thank you so much! It really works
