Can I get the overall cook state easily?
   2093   3   0
I want to get the overall cook state's information like the new PDG toolbar UI. On how many nodes or work items have been cooked, and how many been waiting for cooking.
Now I use code like this:
ctx = node.context
workitems = [i.state for n in ctx.graph.nodes() for i in n.workItems]
completes = workitems.count(pdg.workItemState.CookedSuccess)
And I want to get reported (print some logs) for every work item when it get cooked, so I put the code to the WorkItemStateChange EventHandler.
It works but sometimes the work item hanging on cooking state and never gets cooked. So is there any convenient way to do such thing?
Thanks.
Edited by EricSheng - June 16, 2020 02:10:51
Which version of Houdini are you using?
Edited by joabs - June 16, 2020 13:24:03
joabs
18.0.391
Unless you're seeing wrong information in the toolbar or in the TOP nodes, it is safe to assume the events are correct, as both relies on them. You might be running into data race issues, try using a lock around your code.
