Ruler tool
   3648   0   0
Hey everyone! Happy to announce to a new addition to Sidefx Labs, the Ruler tool!
The Ruler tool is an nodeless viewport state for measuring distances on geometry. With it, you can quickly get values for the rough sizes of different features on the geometry, and use these measurements to inform your decisions about parameter settings. For more precise measurements, you can turn on point snapping or grid snapping. You can also enable angle-snapping, for locking your measurement to make a specific angle with regards to the x, y, or z axis.
The measurements can be copied to the clip board for quick pasting into parameter fields.
You can add as many measurements as you like, but keep in mind they are ephermeral and will disappear once you exit the viewer state.
You can access the tool through the Sidefx Labs shelf, or from the Tab menu while your mouse is over the viewport.
The tool currently only works inside a SOP network, and you must have the display flag on a node.
And you will need the latest Labs release to get it, (at least 509).
https://www.sidefx.com/tutorials/ruler/ [www.sidefx.com]
