Outputting the Nth animation frame of a simulation?
   2281   2   0
Hi, this is probably a simple question, but how do you use Houdini Engine to get a specific animation frame from the plugin?
I have a RDB solver that clusters some objects that fall over a small period of time. I made an HDA of it and imported it into Unity, but I can only get it to show the first frame. I don't want an animation, just the static geo at frame “N”.
Messing with the animation start/end doesn't seem to work for me. The solver in question is the RBD bullet solver.
No response to this.
I've heard you can set $F in the graph to force the simulation to that frame, but I can't figure out how to do this. Is this the intended way?
Add a TimeShift geometry node to end if your graph, and set the frame there.
