Hello
got problem
did all step by step from here https://www.sidefx.com/products/houdini-engine/plug-ins/unity-plug-in/ [www.sidefx.com]
inside unty getting this error
Loading Asset Library From File : HAPI Error: No Valid Licenses Found
- HAPI_LICENSE_MODE unset or is set to ‘default’ meaning Houdini Engine will first try to acquire a Houdini Engine license and if one is not found it will try to acquire an interactive Houdini license (Houdini Core then Houdini FX).
- No Houdini Engine license found.
- No Houdini license.
- No Houdini FX license found.
- No Houdini Engine Indie license found.
- No Houdini Indie license.
If session is invalid, try restarting Unity.
UnityEngine.Debug:LogError(Object)
HoudiniEngineUnity.HEU_SessionBaseetSessionErrorMsg(String, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionBase.cs:189)
HoudiniEngineUnity.HEU_SessionHAPI:HandleStatusResult(HAPI_Result, String, Boolean, Boolean) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionHAPI.cs:746)
HoudiniEngineUnity.HEU_SessionHAPI:LoadAssetLibraryFromFile(String, Boolean, Int32&) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Sessions/HEU_SessionHAPI.cs:1046)
HoudiniEngineUnity.HEU_HoudiniAsset:LoadAssetFileWithSubasset(HEU_SessionBase, Boolean, Int32) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:1876)
HoudiniEngineUnity.HEU_HoudiniAssettartRebuild(Boolean, Int32) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:862)
HoudiniEngineUnity.HEU_HoudiniAsset:processRebuild(Boolean, Int32) (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:786)
HoudiniEngineUnity.HEU_HoudiniAsset:AssetUpdate() (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_HoudiniAsset.cs:586)
HoudiniEngineUnity.HEU_AssetUpdater:Update() (at Assets/Plugins/HoudiniEngineUnity/Scripts/Asset/HEU_AssetUpdater.cs:84)
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()
i see menu houdini, can make some changes in options, but cant generate geometry from example.
what i did wrong?
tried unity hdrp and standart pipline
version 2019.3.15f1
cant get start with unity and houdini
3380 2 0- zelmund
- 4 posts
- seelan
- 571 posts
Do you have Houdini installed? Does it running properly? Which license is it using? Please submit license diagnostic info to support@sidefx.com if you are still having issues. https://www.sidefx.com/faq/license-management/#faq357 [www.sidefx.com]
Edited by seelan - July 3, 2020 10:32:27
- zelmund
- 4 posts
seelanyes. version 18.0.499
seelantried to do something there (simple move view by mouse), but crushed twice.
seelandownloaded Houdini for indie, but when i try ti start it i see Houdini Apprentice and it crush every time i try yo see “About” window - its crushing.
