Increase resolution of a field in DOP
   5072   1   1
Is there an easy way to increase resolution of a field in DOP? Example: I have `surface` field with resolution and I would like to increase it to while keeping field's size and position.
I expected that `Gas Resize Field` would be able to do this, but I have not figured how.
Is there a reason you can't prepare your surface field at the desired resolution from the get go? Otherwise you can try using the Gas Calculate DOP to copy the surface field into an empty field that has the resolution you need.
