hello,
is there a short way to get the node associated with a spare input?
in hscript you can access them via -1 etc.
the best way i found was evaluating the spare input as a parameter, which is a little to much code for simple expressions.
this is one of the reasons i still didn`t switch from hscript to python expressions.
if there is no such function already i would like to propose it as an added feature.
thanks
get spare input with python
3673 2 0- jkrein
- 5 posts
- mearg
- 1 posts
- EJaworenko
- 54 posts
This works as a means of grabbing the iteration value of a spare input (in a for each loop with the metadata node connected to -1):
nodeParm = hou.pwd().evalParm("spare_input0")
node = hou.node(nodeParm)
num = node.geometry().intAttribValue('iteration')+1
Houdini TD, I focus on tools for procedural asset creation.
www.jaworenko.design
