DSO Error (126): SOP_RealityCapture.dll
   5125   6   1
Just installed clean Windows with clean Houdini Indie 18.0.532 production build via Houdini Launcher and clean Redshift 3.0.25. Added RS lines in the .env file and now have loading error on each Houdini launch:
Houdini DSO Error (126) Couldn't load C:/........532/houdini/dso/SOP_realityCapture.dll This is probably because this file was intended for use with a different version of Houdini.
Seems weird since as far as I know RealityCapture is a part of SideFX Labs and I didn't installed it.
Tried to search. Found similar topics in the past. Reinstalled Redshift and Houdini itself. No luck.
What did I do wrong?
Edited by rozhabrev - Aug. 15, 2020 21:30:34
UPD: Switching to RS 3.0.24 solves the issue. Weird.
Hi I just met the same problem but when i switch to redshift 3.0.24 it still doesnt work…
houdini.env (527 bytes)
Hey… I too am having the same problem exactly as described in the original post. Running houdini 18.0.499. I do not run into this problem if I take out the script added to houdini.env that allow redshift to run.
hi, for me this solution work
download the reality capture software, install it.
and after add this line to your houdini.env
PATH = “C:\Program Files\Capturing Reality\RealityCapture;$PATH”
HOUDINI_PATH = “C:\Program Files\Capturing Reality\RealityCapture;&”
HOUDINI_DSO_ERROR = 2
maximilien
I actually did all of the above and still nothing worked. Actually after installing reality capture it made it so houdini doesn't even open now.
http://vimeo.com/garretthoyos/demoreel [vimeo.com]
http://animation.byu.edu/ [animation.byu.edu]
garretthoyos
Any luck? I'm running into this exact issue. I'm wondering if it has to do with the houdini launcher install.
