Problem with scripts tab in python sop
   1547   2   0
Hallo, I want to write a scritpt inside a “new digital asset”.
But I cant't chose “python module” in the event handler of the Scripts tab.
Does somebody know what I can do?
Here is a detailed description what I have done so far:
I do the following:
File -> New Asset
In the checkbox I choose
Definition: Python
Network Type: Geometry
In
TypeProperties->Scripts
I want to type my python scirpt. But The event Handler does not work. I cant't create a “python module”. I can choose nothing
Edited by gerd - Aug. 16, 2020 14:50:59
Can you pick other event handlers from the menu like OnCreated, OnLoaded, etc?
If you can't chose anything, it might be a UI bug (that I also was experiencing with menu parameters) and I suggest you to restart Houdini or, better, to install the last build.
I think it really was a UI bug. I installed the latest build and the problem semms to be solved!
Greetings
Gerd
