I am having an issue using the Overlay Text top. I want to overlay the text on my wedge renders and it is taking a really long time to render. I have no idea why since I am running a powerful machine with 48 processors and 128 gb of RAM. I'm not sure why this is happening. I will attach my scene file if anyone wants to take a look.
Thank you
tops overlay text problem
3818 7 1- logix
- 22 posts
- logix
- 22 posts
- tpetrick
- 600 posts
What sort of performance difference are you seeing between PDG vs. a regular ROP Composite?
Using the file you attached, it takes my machine about 20 seconds for the plain ROP Composite node to cook 120 frames of one of the wedges. When cooking one of the wedges with TOPs, it takes around 25 seconds to cook 120 frames. Its expected that PDG takes a few seconds longer because the work item cooks out of process, and has to start a hython process that loads the .hip file.
- logix
- 22 posts
- logix
- 22 posts
- chrisgreb
- 603 posts
- logix
- 22 posts
- chrisgreb
- 603 posts
