I have some issues with instancing and usd. When the “instance To Point” node is set to Internal Sop as Location Source all Point Attributes on the Target Points are copied as expected. “test”, “Cd2 and ”v“ in my example.
But if I use the first input as target, I can not copy them. On point is that the attributes on the target points are renamed to ”primvars:test“, ”primvars:displayColor“, ”velocities“. This happens with sop sources and abc file sources as well.
So how do I copy the attributes, I tried ”primvars:test" but it does not work
I attached a file showing my problem, its a archive with hip, 2 bgimages for houdini and a abc.
Thanks for Your help
Transfering attributes from usd graph objets to instances
3568 0 2- sanostol
- 577 posts
