Hi Everyone,
I did the (perhaps) classical error of trying to cache a pyro sim with a File Cache node. It obviously didn't work, well… it cached out the sim but it just wont read it.
Then I tried using what seems to be the right node, DOP I/O but when I send the sim to cache it just takes a second and nothing is cached.
Could anyone please hint a possible mistake I am doing?
FYI, in the Import from DOP tab I put what I think is the correct node in the DOP Network slot (obj/sim)
and in the DOP Node I put obj/sim/pyrosolver.
I am on Houdini 18. Indie license.
Many thanks,
R.
Caching Pyro nightmare
3065 4 1- Richard Klein
- 31 posts
- AslakKS
- 187 posts
I believe that you're not actually not getting the pyro data from the DOP I/O
The DOP node needs to point to the DOP object, so for you it's probably “obj/sim/smokeobject1” and remember to specify whitch fields you want to import.
If you don't see anything when playing back the simulation with the DOP I/O node its not importing anything. Could also check with middle click on the node at the second simulation frame, you should see your pyro fields listed there.
- Richard Klein
- 31 posts
- Richard Klein
- 31 posts
- AslakKS
- 187 posts
