I created a Pyro sim and then I have imported a .obj model into Apprentice 18.0…I tried to turn it into a static object to react with a Pyro sim. No collision is happening. Is there a limitation on the Apprentice version or am I overlooking something? I have only tried applying a static object shelf tool to the object but the fire won't collide with it.
COLLSION NOT WORKING ON IMPORTED .obj IN HOUDINI APPRENTICE
1757 2 0- SeanMorgan1962
- 8 posts
- jsmack
- 8041 posts
SeanMorgan1962
Apprentice has the same functionality as FX, except for render/export features, so probably.
I can't say why the collision isn't working, but there could be many reasons. Is the volume conversion high enough resolution? Is the object a closed mesh? Is it too thin?
I can only guess without seeing a scene file
- SeanMorgan1962
- 8 posts
