ROP fetch service for hqclients
   2917   4   1
Its possible to run services on hqclient machines? if so, how can I do it? Unfortunately the UI for creating a service has the scheduler option always grayed out.
Thank you!
Alejandro
Currently only local machine services are supported, so it's not currently possible. However, adding support for PDG services to the HQueue Scheduler is on our roadmap.
BrandonA
Amazing!! thank you very much for the info!
Is there a recommended way to use rop services? I use a Threadripper 32 Cores and I opted for a pool size of 32 rendering a bunch of cop rop operations in parallel. Confusingly it always runs 63 Jobs in parallel disregarding the pool size and the local scheduler settings.
Are the ROP fetch services still on the roadmap or they are already implemented in the latest Houdini version?
Thanks,
Alejandro
Edited by Alejandro Echeverry - May 11, 2023 18:35:39
