Bend and Taper SOP isuue...
   Views 2154   Replies 3   Subscribers 0
Hi;
I would like to apply taper in just one direction as you can see in the image below.
How is it possible in Houdini?
Masoud Saadatmand (MSDVFX)
In this case you may need to fall back to a Pointdeform Sop or a lattice.
Martin Winkler
money man at Alarmstart Germany
Houdini Color
https://forums.odforce.net/topic/47343-bend-and-taper-sop-isuue/?tab=comments#comment-220014 [forums.odforce.net]
Edited by Librarian - Oct. 31, 2020 11:44:07
If your taper direction is Y for example and the scaling directions are X and Z, you can also store the original point, apply your taper and restore one component after the taper operation. This is only a quick workaround.
Edited by Aizatulin - Oct. 31, 2020 18:51:01
taper.hipnc (163.2 KB)
