I am looking for a really simple way to cause the value in my RS_Incandescent shader to randomize in quick intervals, simulating the flickering pattern of a neon bulb. I was looking at some noise functions, but I don't see a way to control them to make them do what I want. Also I'm still kinda green in VEX.
Any ideas are appreciated!
Simulating neon bulb flicker with VEX
2547 1 1-
- fabiobasile
- 28 posts
- Enivob
- 2637 posts
You could use an hScript expression in the intensity field. Try something like this…
This will give you a random value per-frame between 0.15 and 1.15. Adjust values as needed.
fit01(rand($Frame), 0.15,1.15)
Edited by Enivob - Nov. 15, 2020 09:19:18
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
