Duplication finder in radius
   1943   2   1
Hi All!
I have a VEX problem,I have a point cloud and I use it for instancing various objects to it. I would like to search all points in a radius and replacing the identical instances to an another what is not there. Like this I could get a nicer variation because the same instance would not be placed next to each other.
My theory was this :
- using pcfind search all points in a radius and put the variations into an array
- remove the source point value from the array
- pick a random one from the array and replace the identical neighbours
- run through this on all points
For some reason something does not work and If someone could help me that would be amazing !
Thanks a lot !
Karoly
Create_Point_Array.hiplc (72.6 KB)
What you are trying to solve is essentially a graph coloring problem:
https://www.sidefx.com/docs/houdini/nodes/sop/graphcolor.html [www.sidefx.com]
Hi animatrix_
thanks for the fast answer ! Its kind of the same but not what I want , the graphcolor is too ordered . At least what I could do with it . I would like to set a radius for the inspection not just watching the closest points and I have at least 20 variations for the instancing. If i canould solve it with this node could you help me please ?
my vex code :
int pts = pcfind_radius(1, “P”, “pscale”, 0.0, 1 , 4, 5 );
string instance_array = s@unreal_instance;
removevalue(instance_array, s@instance);
foreach(int pt; pts)
string instance_string = point(0, “instance”, pt);
removevalue(instance_array, instance_string);
if(s@instance_string == instance_string)
s@instance_string = instance_array;
Cheers
Karoly
Edited by anon_user_54997945 - Dec. 9, 2020 09:54:12
