Using command chain with existing xmlrpc server
   2141   2   2
Hi Im trying to use houdinis command chain with an existing xmlrpc server that Im running outside of houdini. I might be misunderstanding how it all works!
Im starting with the example here -
https://docs.python.org/3/library/xmlrpc.server.html#module-xmlrpc.server [docs.python.org]
from xmlrpc.server import SimpleXMLRPCServer
from xmlrpc.server import SimpleXMLRPCRequestHandler
class RequestHandler(SimpleXMLRPCRequestHandler):
    rpc_paths = ('/RPC2',)
with SimpleXMLRPCServer(('localhost', 8000),
                        requestHandler=RequestHandler) as server:
    server.register_introspection_functions()
    # Register pow() function; this will use the value of
    # pow.__name__ as the name, which is just 'pow'.
    server.register_function(pow)
    # Register a function under a different name, using
    # register_function as a decorator. *name* can only be given
    # as a keyword argument.
    @server.register_function(name='add')
    def adder_function(x, y):
        return x + y
    # Register a function under function.__name__.
    def mul(x, y):
        return x * y
    server.serve_forever()
It works great! I can connect to it outside of houdini and run the example functions. all good.
I can also connect to this(external to houdini) server in tops using a python command chain using the "connect to existing server" option.
As soon as I add a "send command" top to this command chain I get the following error-
Error running callback 'onCookTask': sharedserver info is invalid for name 'localscheduler/sharedsever0'
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/pdg/types\utils\commandchain.py", line 205, in onCookTask
raise pdg.CookError("sharedserver info is invalid for name '{}'".format(server_name))
CookError: sharedserver info is invalid for name 'localscheduler/sharedsever0'
I dont understand what is happening here. This happens even if the send command is blank.
There are particular RPC functions that 'sendcommand' expects to be available to execute the script. You should base your server on the implementation in $HHP/pdgjob/genericrpc.py, which is what is used by the other command chains.
For example you can run
python.exe $HHP/pdgjob/genericrpc.py --start --host 0.0.0.0 --port 59902 --log c:/temp/myserver.log
To start a python command chain server that can be connected to.
Edited by chrisgreb - Dec. 13, 2020 10:32:35
Hi Chris, thanks I had a go at running the genericrpc.py and I was getting the same error.
BUT
Ive had a second think about why im even using a command chain. I can set up my own server and run functions using xmlrpc in plain old "python script" top nodes which seems to be working.
