FEM sliding constraint example
   1679   4   0
Hello, has anyone gotten the new FEM sliding constraint to work? In a simple example it just behaves as fixed constraints between the two FEM objects. I can't get any sliding behavior. What's the secret? Thank you!
I've discovered that the FEM sliding constraint does not work with the stable neo-hookean variant. The correct behavior is only seen when using the Corotated Linear model. I believe that this is a bug as it is not advertised to only work with the specific corotated model. Using Houdini 18.5.351
FEMslideConstraintBug.hip (219.5 KB)
screen-capture of the behavior:
FEMslideBug.mp4 (2.4 MB)
https://www.sidefx.com/forum/topic/15603/ [www.sidefx.com]
Already logged it, just wanted to see if anyone else has seen this or had work-arounds?
