cops: how to normalize a normal map?
   Views 2258   Replies 4   Subscribers 2
Hi!
I'm trying to make a normal map of a vdb cloud. I've coposited renders of the cloud and I get something close to a normal map. Is there a node to normalize the result? ...or is it possible to write vex in there?!
-Olivier
...On another note, I'm getting some odd gliches. Anybody knows what can cause this? it's in my composite view but if I look at the preview on the node itself, it looks good. And when I export a .exr of it, the glitch is there too.
-Olivier
Edited by olivierth - Dec. 24, 2020 16:05:34
Hey, you are looking at a unpremultiplied channel in the exr, you should see some render garbage. If you want it to look right you should premultiply the image, just remember you need a unpremultiplied normal map if you want it to work properlyso this would just be for your viewing pleasure.
hope this helps
If Your normal maps is not normalized You can do it in a vopcop2filter in a COPNetwork, connect the RGB float channels to a "float to vector" node, normalize the output and write it back to the output channels
GlobalRGB>floattovector>normalize>vectortofloat>RGBOutput
Thanks for the replies, I'll check that out.
