How to create an instance with same parameter interface?
1683 1 0- DedRed
- 2 posts
Is there a way to create an instance that keeps the custom parameter interface created in the "master" node? So that I can have a bunch of instances with unique parameter values (of custom parameters I've already created in the "master" node). I would like have only place, in the master node, where I can fiddle with the underlying logic that would get propagated to all the instances. If there's another way to accomplish the same thing I'm open to it.
- dssve
- 3 posts
Did you get an answer to this? I have the same question. I have a "frame element" (like the side of a picture frame) that is a geometry node which exposes a parameter interface to change the length.
I copy those planks to points — but I need to be able to set the length for each instance of course. How do you do this usually?
Thank you!
Thank you!
Edited by dssve - Dec. 24, 2021 03:15:46
