How to set Actor Hidden In Game or Hidden in Game by HEngine
   4867   2   0
primitive attribute :
i@unreal_uproperty_ActorHiddenInGame = 1
i@unreal_uproperty_HiddenInGame = 1
not work.
You can do it like this: https://i.imgur.com/8Xtm45E.png [i.imgur.com]
I'm not sure if dtlendvaj's method has worked for you, but I just wanted to give a detailed explanation if somebody encounters a problem with "unreal_uproperty_" attributes and how to solve them:
Unreal Engine C++ runtime reflection system for setting UProperty types through FObjectEditorUtils::SetPropertyValueis a bit weird, and I believe this is what Houdini internally uses. Currently Unreal Engine is only able to set the first UProperty member name that it encounters in the Blueprint (or C++) class through the mentioned method. Moreover, you need to ensure "XXXX" of "unreal_uproperty_XXXX" is identical to how it is named in the C++ class, it doesn't consider customized Blueprint naming.
For example, if you got a Blueprint (or C++ Class), TestClass, in Unreal Engine with following member variables:
struct TestStruct{
    int _memberOne = 0;
class TestClass{
    int _memberOne = 0;
    TestStruct _testStruct;
Then "unreal_uproperty_memberOne" attribute will only set the first _memberOne it encounters. If you write "unreal_uproperty_Member One", it will not match and set this attribute, it has to be written as "unreal_uproperty__memberOne" even if Blueprint would show it as "Member One".
Also, some of these UProperty variables are hidden inside member structures, currently Unreal Engine can't set these properties through the FObjectEditorUtils::SetPropertyValuecalls. For example, _memberOne of _testStruct won't be setable through "unreal_uproperty_".
One solution is to create _houdiniMemberOne variable for use by Houdini only. Set it through "unreal_uproperty__houdiniMemberOne" and then let C++ or Blueprint code set _testStruct._memberOne variable.
It is very convoluted but I doubt Houdini will be able to solve this issue, ideally Unreal Engine should revise their method of FObjectEditorUtils:etPropertyValue.
Edited by volkan-ozdemir - Jan. 11, 2021 17:21:32
