Quick way to switch to OCIO?
   1923   5   2
Is there a way to enable/disable OCIO from within Houdini without editing houdini.env and restarting the app? Nuke and Maya let you just turn it on and off at will.
UPDATE: Figured it out. Used hou.setenv and hou.unsetenv to create shelf tools to load and unload OCIO. Easy!
Edited by BrianHanke - Jan. 8, 2021 19:42:12
Can you just disable it in the viewer you need it disabled for with the color correction bar?
jsmack
Yeah, but it still leaves the 75,000 menu items related to OCIO in any plugins and viewers. At least my quasi-solution removes them from viewers. Sadly, any loaded plugins will behave as if OCIO is still active. In Maya if you untick color management it removes all OCIO stuff from Arnold menus, etc.
BrianHanke
Came across this post while using both Redshift and Karma XPU. I am interested in switching between Redshift's and Houdini's OCIO configurations without having to restart Houdini. Would you be willing to share a script for loading and unloading OCIO? 🙏
Oh man, I don't even remember making this post. You could create a shelf tool with some Python:
hou.putenv("OCIO", "/path/to/config.ocio")
That might work... But I don't know if Houdini supports "hot" loading of an OCIO config like that. No harm in trying it out though.
Edited by BrianHanke - Sept. 9, 2024 11:21:44
I don’t know why, but the Redshift OCIO config doesn’t work with Karma.
The MaterialX image node seems to ignore the color rules.
Here’s how to hot-reload custom OCIO configs:
hou.putenv("OCIO", hou.expandString("$HOUDINI_USER_PREF_DIR") + "/ocio/rs_config.ocio")
hou.Color.reloadOCIO()
