Dear,
I read everything and tried a lot of test but i don't understand the follow behavior:
1) CopyToPoint with a Circle as Source and a Grid as Target.
The result is perfect, the circles as replicated to each points of the grid
2) CopyToPoint with a PolyDraw as Source and a Grid as Target.
The CopyToPoint node correctly replicate the Polydraw to each points of the Grid but on a difference position of the scene. WHY?
I don't undertsand what I missing. The Houdini manual doesn't mention that I need to set something (attribute, for instance) when I want to use a PolyDraw as source of CopyToPoint.
Where am I wrong?
Thanks for the help.
Claudio
CopyToPoint with Polydraw node as source and grid as Target
1578 2 0- ClaudioFerroni
- 8 posts
- protozoan
- 1720 posts
- ClaudioFerroni
- 8 posts
Yes! Thanks a lot :-) ... it works ... now I can solve similar future issues even if I didn't understand WHY! For witch internal reasons Houdini needs this "Move centroid to origin" (not documented on the online manual) in a transform node after a PolyDraw and not for a Circle, Cube, Sphere o other nodes.
I'd like to understand.
Ciao
Claudio
Ciao
Claudio
