Initial values for scriptMenuStripRadio items in custom menu
   977   1   1
Hi there,
Does anyone know how to initialize the selection of a scriptMenuStripRadio item in a custom menu? I'm able to create it, and use the variableValues from it just fine, but when first opening the menu, none of the radio items are selected. I can't seem to find anything obvious in the docs [www.sidefx.com], and the built-in menus seem to do it magically*.
Side note - the same applied for setting scriptToggleItems to start enabled (1).
Edit: * from MainMenuMPlay.xml:
<menuStripRadio id = "anim_loop">
<value>loop.val</value>
<radioItem id = "loop"> <label>Loop</label></radioItem>
<radioItem id = "once"> <label>Play Once</label></radioItem>
<radioItem id = "zigzag"><label>Zig-Zag</label></radioItem>
Not exactly sure where
loop.val
comes from
Edited by jamesr - Feb. 6, 2021 23:52:04
Did you ever figure this out?
I am hitting the same thing, and none of the radio buttons is selected, which should never happen of course, as by definition, a radio button always has 1 selected.
