Hey all,
Does anyone have the vex equivalent of the group expand node?
why:
I want to contract a group by n levels and then expand it again by n levels to get clear out of singleton points that are not connected to the main body of points.
this is to clean up the results of an Attribute Transfer node that has pieces that are overlapping and the values need to be part of a single island so I can use it in a point deform node as the piece attribute.
Vex equivalent of Group Expand node?
2798 2 0-
- geordiemartinez
- 45 posts
- animatrix_
- 4863 posts
You can use neighbours and polyneighbours functions:
https://www.sidefx.com/docs/houdini/vex/functions/neighbours.html [www.sidefx.com]
https://www.sidefx.com/docs/houdini/vex/functions/polyneighbours.html [www.sidefx.com]
This one does it for points:
function int [ ] getPointNeighbours ( int geo; int ptindex; int depth; int accumulate ) { int pts [ ] = array ( ptindex ); int lastpts [ ] = pts; for ( int i = 0; i < depth; ++i ) { int newpts [ ] = { }; foreach ( int pt; lastpts ) { int connected [ ] = neighbours ( geo, pt ); foreach ( int c; connected ) { if ( find ( pts, c ) < 0 ) { append ( pts, c ); append ( newpts, c ); } } } lastpts = newpts; } if ( accumulate ) return pts; else return lastpts; } int pts [ ] = getPointNeighbours ( 0, 42, chi("depth"), chi("accumulate") ); foreach ( int pt; pts ) setpointgroup ( 0, "pts", pt, 1 );
- geordiemartinez
- 45 posts
Animatrix, this is great! thank you. I was able to adapt that.
Here are the two functions I came up with with help from Animatrix_ to contract a group:
function int [ ] groupexpand ( int geo; int pts []; int depth ){ //int pts [ ] = expandpointgroup(0,groupname); int lastpts [ ] = pts ; for ( int i = 0; i < depth; ++i ){ int newpts [ ] = { }; foreach ( int pt; lastpts ){ int connected [ ] = neighbours ( geo, pt ); foreach ( int c; connected ){ if ( find ( pts, c ) < 0 ){ append ( pts, c ); append ( newpts, c ); } } } lastpts = newpts; } return pts; } function int [ ] groupcontract (int geo; int pts []; int depth ){ //int pts [ ] = expandpointgroup(0,groupname); int lastpts [ ] = pts ; for ( int i = 0; i < depth; ++i ){ //printf("lastpts loop %d len: %d \n",i,len(lastpts)); int rempts [ ] = { }; int keeppts [ ] = { }; foreach ( int pt; lastpts ){ int connected [ ] = neighbours ( geo, pt ); foreach ( int c; connected ){ if ( find ( lastpts, c ) < 0 ){ if (find ( rempts, pt ) < 0 ){ append ( rempts, pt ); } } } } foreach (int kpt; lastpts){ if (find(rempts,kpt)<0){ append ( keeppts, kpt ); } } lastpts = keeppts; } return lastpts; }
Edited by geordiemartinez - Feb. 12, 2021 18:12:53
