WELCOME! + RULES
   Views 11090   Replies 19   Subscribers 4
Welcome to the MARDINI Daily Art Challenge which gives the Houdini community the chance to compete for cool prizes by creating a new image or animation every day during the month of March 2021.
Each week has a theme which you can see in the graphic below and each day has a prompt which is meant to inspire the artwork that you submit.
You can learn about rules and prizes HERE [www.sidefx.com].
Here are the prompts:
Thank you for this SideFX!
I recently started learning Houdini and I am so excited for this as it will definitely speed up my learning process by inspiring me to put more hours in creating.
Could we use displacement and normal maps, as they are kind of geometry?
Regards,
McMacabre.
Hi, I was wondering if it was possible to render our scene inside a GameEngine like Unity/Unreal?
McMacabre
Regards,
McMacabre.
Texture Maps such as Displacement and normal maps are allowed.
Orson Favrel
No. Any rendering needs to be done within the Houdini Environment. Third Party renderers such as RenderMan, Redshift, Arnold, 3Delight... are allowed.
Do we have to Comp in Houdini? If so, does COPs support DeepEXR?
Houdini Indie
Karma/Redshift 3D
Daryl Dunlap
If you are going to COMP it should be in Houdini. The results should be the image or movie in a flattened format.
Hello, is it allowed to render with the free redshift plugin?
So there are watermarks in the video.
Looking forward to this. Thanks for the push to keep diving further in.
JanHebein
Can we use external devices to do raw motion capture? Then import it into Houdini for animation retargeting using Kine FX.
So is the deadline each day midnight EST or EDT? Since its gonna change mid March and I don't live there I'm kinda confused.
In the initial rules said EDT, but in the Day 1 Bounce forum initial post says it's EST... so ..
Is is fair to say that if it's time stamped before 12:00 am of next day on the forum post I'm safe?
Can we use our own hda, hda from sidefxLabs or straterkit?
bubblepins
Sure - if it gets you into working with KineFX then that is our goal
robonilla
It is EST until the time change then it will move to EDT.
Would it be possible to open the forum threads for the next couple of days ahead of time so that those of us that actually need to go offline for a day or two will still be bale to their submission in on time?
ZaynabSk
why i can't post
If it is your first time posting to our forum then it has to be reviewed. You are good to go now
JoeFly
Sorry - didn't see this until the weekend is over. It has worked well so far with each day's challenge being posted at the beginning of the day. Posting too many threads too early could confuse people on which entries are due when and cause some chaos.
If you are in this situation where you weren't be able to post on the actual day but your entry was ready on time email me at rmagee@sidefx.com and I will make sure you get the 1 participation point.
Is there a resolution restriction for animation?
BerkErdag
No - higher the better but we realize that some people may be working with slower setups - Do the best you can! 1920x1080 for animations would be a good target if possible. Some people use different aspect ratios which can also save on render time.
